I am wondering why I only get pitch buildup on one side of the saw blade on my circular saw. It seems to be cutting OK with no burning etc. I could not find anything on line to explain this. Has anyone else seen this?
2364i (1541) Kohler ECH23 Power Steering 54" Deck 451 Snow Blower 42" Plow |
I would think the saw "set" is more to one side than the other, but I ain't no carpenter
Lots of identical cuts? Assuming it's not the wood/cut and the blade is true, not sure
Why Farm Half When You Can Farmall? 1282 | 44C Deck, Chains, 42" Blade, Cast Weights, 020" Over K301 * 1711 | 50C Deck, #1 Rear Rototiller w/ Extensions, Sleeve Hitch, KT17S Series II 24302 --> CH18S * 1811 | 46 GT Deck, 42" Blade, Chains, M18 Magnum, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck |
1)Saw plate (base) or saw mounted guide maybe be out of alignment with the blade. Usually most circular saw don't have any real adjustment.
2). If you are cutting free hand, you could have tendency to lean on or push crooked. Remember, the handle on saw is usually offset the centerline of blade. Use guide when possible. 3) Blade has a warp or bend. Do you see pitch on certain parts of the one side of the blade? 4) Wet/green lumber. Also, there are many dried lumber that has tension which is released when cutting and it sometimes pinch or bind the blade.
Two 125's and a 124 all with 42" decks Plow blade #2 Cart QA36 snowthower |
