Old 06-15-2022, 08:41 PM
Tom Dowling Tom Dowling is offline
Default 682 mower PTO switch
The toggle switch for my pto won't stay engaged unless I hold it in the on position, I thought it was a bad switch so I replaced it with a new one and still in order to keep the electric clutch engaged I have to hold it in the on position. Does anyone have an idea what would cause this? It did work earlier this spring.
Thanks, Tom It's a red one serial # 729423. I figure things have been rewired and bypassed over the years, since I've owned it it has never shut off the mower when backing up.
Old 06-15-2022, 09:32 PM
The Reverse Relay and/or wiring connected to it, could be, or is bad.
Old 06-16-2022, 06:56 AM
1711Cub's Avatar
1711Cub 1711Cub is offline
Lightbulb
So the production sequence number is really quite necessary to properly answer this question, as the wiring changed during the 682's production run.
I would be looking at the seat switch for this problem.
Old 06-16-2022, 07:06 AM
A Chassis Serial Number is needed to pinpoint and accurately help you with your problem.
Old 06-16-2022, 05:41 PM
On the 782 (much like the 682's) the early ones physically stayed in the on position after PTO was selected.
Later ones physically returned to the neutral position after PTO was selected as they had a relay that was actuated by the PTO switch, so the switch could return to neutral position,but PTO remained on.
This was in compliance to newer safety rules in the reverse interlock circuit.
So as stated, serial number break is important.
It prolly was when MTD took over but I have not researched it.
IIRR it was so the PTO stopped when reversing the tractor.
That way you could not run over yourself sitting on the seat, while backing up
Old 06-17-2022, 10:19 AM
Farmall450's Avatar
Almost as useful as the gas cans that force you to spill.
Old 06-18-2022, 07:55 AM
One of my favorite regulations it requiring a tarp/cover for gravel trucks.
it is like rocks jump right up into the air and out of the truck damaging a windshield.
NOOOOOOOOO, they sling out of tire tread and if you happen to be in the wrong place in time you get a rock in da window.
But the do gooders just had to make a regulation to stop the "carnage"
Make a law, stop a problem!---- yep Gubber-mint at it's best.
I'll stop before this train really gets derailed
This post is about a switch, -----or was it switching trains
Old 06-18-2022, 09:00 AM
ironman's Avatar
ironman ironman is offline
It was about switch positions.....
or was it about switching positions????
Old 06-18-2022, 09:51 AM
Workingstiff Workingstiff is offline
⚠️CAUTION ⚠️ Coffee is hot! It will burn your crotch!
'76 1200 Dad bought
'75 1200 "Twinsie" per my daughter
Old 06-18-2022, 10:00 AM
Frank1541 Frank1541 is offline
Funny, I watched the gravel fall off the overloaded dump truck and fly into my windshield.
2364i (1541)
Kohler ECH23
Power Steering
54" Deck
451 Snow Blower
42" Plow
