Old 08-17-2010, 04:00 PM
Leon renaud Leon renaud is offline
Default Need help ,104 creeper needs work
I tried a search but can't find what I need found out that one of our 104s has a creeper but it will not stay engaged in the rear position.Can anyone link me to a online service manual or any info on creepers so I can trouble shoot this one?
Thanks Leon
Old 08-17-2010, 10:50 PM
Leon, I took this off of a 104 to put in my 126 and I had to replace the seals and some bearings. It was nasty inside. I don't know if this is your problem but in the second picture the case has an indent for the shifter poppet to hold in gear. It may be that it is too loose causing it to fall out of gear.
Old 08-17-2010, 10:51 PM
That or the shift fork is so worn that it can't slide the collar all the way on. I would take it off and see what's going on.
Old 08-17-2010, 11:04 PM
Sminkey
Guest
Posts: n/a
Hello Matt, you have some serious Cub knowledge, much respect! I'm having the same issue on the O' I just got and was wandering if you had any insight to why it won't stay in direct drive, stays in under drive fine and works in direct, but have to hold it there. Thanks, appreciate any help!
Old 08-17-2010, 11:22 PM
It could be something similar, but I have never had or been into an O creeper, so your guess is probably as good as mine. I want to say those aren't the same design, but I don't know for sure. I know basically everything inside is NLA, so I'd take it off and see what's going on so you don't break something.
