Old 03-29-2021, 08:44 PM
CubbyRI CubbyRI is offline
Default Steering coming along
Got the rusted out steel tube outta the steering box by heating the aluminum with a heat gun, and the broken steering box had a better tube with no rust. I stripped the paint with Rustoleum aircraft paint stripper. I made a bushing for the end which will have a bronze bushing inside it. I won't make a seal just grease it really good. With the new everything this should have way less steering wheel slack and should turn easier. I wonder how much a difference that "ez steer" thrust bearing on the steering box will make?
File Type: jpg 20210329_185949.mp4_20210329_203905.448 (Medium).jpg (21.1 KB, 249 views)
Model 100 Dec 2020 - Running condition, has snow plow!
Model 123 Nov 2020 Hydro needs much work, or resto, building front end loader for this one
Model 100 Feb 2019 apart for total frame-off / sandblast etc resto
Model 70 Sep 2020 needs total resto and an engine, or for parts
Model 70/100 Mar 2021 buried in rust, frozen engine, got free for parts.
two spare hydro rears
"in for a penny, in for a pound!"
Old 03-30-2021, 06:38 PM
For those who might want to try something different (and have access to a lathe) - Finished the steering column top bushing. Pressed it into the thin tube with interference and jb weld, pressed into the bottom just on interference fit. Bored out the bronze bushing after pressing it in with hydrailic press - it went in tight. Next, put it back together and then back into the tractor. (Plenty more chances to screw something up!)
Old 03-30-2021, 07:57 PM
Billy-O's Avatar
Billy-O Billy-O is offline
Some people have suggested a bearing will fit nicely in the tube. IIRC....the bearing is similar to the ones used on the front wheels. These bearings have a lip, too!
Plow blade
#2 Cart
QA36 snowthower
Old 03-30-2021, 08:09 PM
didn't think to do that. But a ball bearing might be overkill, the steering shaft only turns back and forth a bit. I figure this cant leak water in except past the shaft and that will be heavily greased... I dunno!
Old 03-30-2021, 09:23 PM
There is a foam seal under the steering wheel on top of the bearing/bushing to keep crap out of there.
Old 03-31-2021, 06:07 PM
Done. (Hopefully right!) Nice and tight that's for sure...
Old 04-03-2021, 09:27 PM
Cleaning up the tie rods... box is back in the tractor. almost have my cub back
Old 04-04-2021, 11:25 PM
Done. Made a stainless pin that was .005" oversize and hammered that in to the knuckle. Its tite. Steering overall seems tite except the cheap new amazon heim joints have the most slop. EZ fix if i can find better ones. But steering now way better than ever.
Old 04-05-2021, 06:15 AM
twoton twoton is offline
Nice job on the repair!
Old 04-05-2021, 11:23 AM
Thanks man. Not perfect but fixed and way better. There was a very slight bind around the middle of the steering I couldnt get out. Wasnt going to take it apart yet again to chase that. With everything hooked up cant even feel it. Steering wheel has like about 1/2" freeplay and thats mostly the sloppy (new) heims!
Also, not sure how much this help, but on the spindles I mixed powdered graphite lubricant into the grease especially on that bottom "washer" that all the weight is on...
Now that I'm a real professional cub cadet repairer lol time to fix the squealing clutch issue
