Old 02-12-2021, 08:17 PM
fxrglide91 fxrglide91 is offline
Default 682 CC belt tensioners
Does anyone have a pic of the front belt tensioners. Mine look crooked. Should they be parallel . I can't figure how to upload a pic.
Old 02-13-2021, 12:54 AM
SS5150's Avatar
SS5150 SS5150 is offline
Assuming you're talking about mower deck idler pulleys- no, they angle back to the right if you are looking at the front grill of the tractor. I think individually each pulley is at a slightly different angle.
I don't have a mower mounted right now to get a good pic for you.
RUN IN THE RED
1872 project
Cub Cadet Pro Z 560 L
Old 02-13-2021, 06:19 AM
YUP, and Amen.
Old 02-14-2021, 10:19 AM
FrankF3's Avatar
FrankF3 FrankF3 is offline
My dad had problems with the angle on those pulleys on the mule drive. He would only get about 3 mowings before the drive belt shredded itself. When it first happened, he thought it was an old dry-rotted belt, but when the replacement did it again after 3 mowings, I knew we had a problem. With yet another belt mounted, I took the look at the path the belt took. Eyeing up the belt as it passed over the pulleys, I could see the right one had a twist and the was pointed toward the rear tire. I was misaligned so much the belt was riding up out of the sheeve as it left the pulley. I took 2 adjustable wrenches and with them adjusted to hold onto the swing-arm for the pulley and with one up near the swing point and the other down near the pulley, I "adjusted" the angle on the pulley so it was pointed toward the drive pulley on the deck. I did the same sightly on the other mule drive pulley. So far, he's gotten 2 seasons with the same belt - big improvement. I don't know how the arm got twisted, maybe it got hit with something while doing other yard work with the tractor. IDK....
1989 - Cub Cadet 1772
38" Lawn Sweeper #196483
60" Haban Mowing Deck #196374
Old 02-14-2021, 10:53 AM
They both should be bent to the right for a 44C, or 50c deck. The 38C should be straight.
Old 02-14-2021, 04:43 PM
FrankF3's Avatar
Thanks, dad had a 60" deck. I don't know how the one arm got really twisted, but it was really off the mark and pointed to left field when he asked me to look at it.
Old 02-16-2021, 08:20 PM
Thanks for the info
