Old 12-31-2020, 11:17 AM
thadscub's Avatar
thadscub thadscub is offline
Default Installing amp gauge on 122
Hi guys,
I purchased a amp gauge and bracket for my Cub Cadet 122. I can't seem to find any info on how they wire into the electrical system.
Old 12-31-2020, 12:24 PM
Go to the Technical Library section for Tractors, and look at the Wiring Diagrams on page #5.
Old 12-31-2020, 04:30 PM
thadscub's Avatar
nothing shows up when i try to click on the wiring diagram
Old 12-31-2020, 04:44 PM
Cubcadet_107's Avatar
Here's the 122 diagram:
Here's the diagram for the next tractor series (which came standard with an ammeter)
All the wire colors are the same between the two. The green wire runs to the neg. terminal on the ammeter rather than going directly to the solenoid. Then an additional red wire (not original to the 122's harness, you'll have to add that wire) runs from the pos. terminal of the ammeter to the same solenoid terminal where the green wire would have gone.
Hope this helps
'70 107 with k301 engine swap
'71 106 with 38" deck
'63 70 "pinkie"
1863 with 54" deck
105 x2 (parts)
Old 12-31-2020, 04:51 PM
Must be something wrong with your device. I had NO problem accessing the Diagrams.
Here is a simplified diagram.
