Old 03-08-2020, 09:31 PM
Mr Bob's Avatar
Mr Bob Mr Bob is offline
Default Delco Starter/Generator
Would anyone know the nut size that fit the field coil lugs that go through the Delco case? I have lost one and can't match at the hardware. I have googled and searched the forum but came up empty. Thanks, and have a great day.
Bob
Old 03-08-2020, 10:17 PM
Billy-O's Avatar
Billy-O Billy-O is offline
Bob
12-24...... I believe you were talking about the nuts for wire hook-up, correct?
Plow blade
#2 Cart
QA36 snowthower
Old 03-08-2020, 10:28 PM
AND, 12-24 is not a common nut,
so you might have to try multiple hwd.
stores.
Old 03-09-2020, 07:34 AM
stores.
Not impossible, but hard to find. IIRC, that is also a Brass Nut too.
Old 03-09-2020, 09:20 AM
Mr Bob's Avatar
Default Delco Generator/Starter
Thanks for all your replies and info. Will start looking at different hardware stores. Does the nut have to be brass? Have a great day.
Bob
Old 03-09-2020, 11:44 AM
cooperino's Avatar
Bob
It was made from brass as to strip out the nut before the stud would be harmed thus saving you the headache of opening up the S/G to replace..It was probably also brass so it would not corrode and rust as quickly being exposed. It doesn't have to be brass to function, but be careful not to over tighten if its made from something else
Old 03-09-2020, 11:50 AM
cooperino's Avatar
This company happens to be pretty close to me.. Not a bad price for 50... but who needs 50 of these lol.. Well, maybe a couple members here do
Old 03-09-2020, 04:24 PM
Mr Bob's Avatar
Default Delco Gen/Starter
I went back to the hardware that I visited twice yesterday. Today, I was armed with the correct size of nut. Manager looked and could not find one. Said he would call Fastenal for me. We went up to the check out counter and as he was calling, he asked me the size again. A clerk was working at end of counter. She had the box that had the correct nuts. It also had the brass nuts which I purchased 3. Wires are back on Starter/ Gen. Oil pan is back on and engine is bolted to frame. Finished putting rest of tractor together. It started right up and I ran it for 30 minutes. Used the new grade eight 1-1/4" bolts for oil pan and they torqued to 35#. Hopefully when I look tomorrow there will be no oil under tractor. Thanks again and have a great day.
Bob
Old 03-09-2020, 04:51 PM
Sounds good.
Old 03-09-2020, 08:05 PM
Billy-O's Avatar
I guess it was a NUTTY day that went well!
Plow blade
#2 Cart
QA36 snowthower
