This is to the mechanical minded. Club cadet ride on mower, Battery charged but the starter will turn the motor till it hits the compression stroke then stops. its like the battery just hasn't got enough to wind it over that bit more. I thought it may have been the battery but it does the same with a brand new battery. Ive taken the plug out and it winds over like a beauty. ive cleaned all the terminals down to the starter and still the same. Any ideas.
First, welcome to OCC.
![]() Since you make no mention as to the model you are referencing, I can only respond in general terms. Typically in situations like this, it usually involves the battery cables. Both cables (positive and ground) need to be clean, bright, and tight, on both ends. Check that out and advise.
What motor? Does it have an ACR?
Ok its a LT 1042, engine Kohler, model sv590s
Ah.. ok. Chances are weak starter. Pretty common on those courage motors. How many hours on it? Dont rule out ACR tho. Also common issue
540hr........
Not IH built, wrong topic forum
