I have 1772 super. The steering wheel needs to be replaced. I have a hard time getting the steering wheel off the 1772. When I get it off I have a 105 Chrome steering wheel on my 1650. Does anyone know if the 105 splines in the steering wheel is the same spline as a shaft in the 1772?
splines are probably the same, but the steering wheel is likely smaller in diameter.
1872 with 50C deck 1862 with 50C deck 1641 with 48GT deck 364 snow blower IH Cub Original with deck GREEN 317 with integral sleeve hitch, front hydraulic |
And it is taller also.
Yes the 105 steering wheel is small in diameter and a little taller. The steering wheel on my super is all buggered up and needs to be changed. I have a professional built steering wheel puller that works perfect removing steering wheels off all my Cub Cadet. But can't seem to budge the 1772 steering wheel is there a trick to getting in them off? I don't want to cut it off but I might have to. I would if I was for sure of the splines are the same on 105.
![]() Quote:
I do this a lot. Just don’t hit it too hard that you knock the shaft out the bottom of the steering box. A couple Swift knocks after some penetrant with tension ought to pop it off.
I’ll also mention I put a 5/16 bolt or something similar size piece inside the tube so as not to mushroom the threads while pulling. Leave steer wheel nut on loose etc. until it pops. Let’s see this puller you have if you don’t mind
Try finding a steering wheel off of a Massey Ferguson 10 or 12. Same style wheel only difference one wheel had a textured finish and one was smooth.
149,682,1641,1711 with a 12hp in it 1 8" brinly plow 1 10" brinly plow 451 snow blower,H-48 International snow thrower 42" york rake with fold down grader blade. |
