Old 03-04-2019, 02:23 PM
chzuck chzuck is offline
Default Front wheels for a 44" deck
Anyone install the OEM front wheel kit on a 44" deck that had the runners on? Wondering if you removed the runners? Anyone have the mounting instructions?
Deck is going on a 1650.
Old 03-04-2019, 06:00 PM
Having the deck height adjusted properly is far better than wheels,,
If you want to stop collisions of the deck with the ground,,
add rollers instead of tires, like the Ariens decks use,,
If you gotta have wheels, use this type wheel, this type will not need a caster that rotates,,
That is the wheel that is on my Cub Cadet mower deck,,,
Old 03-04-2019, 06:50 PM
They are the wheels I was referring to and on a nice level yard one would not need them. I have them on a 48" deck on my 147 and would not do without them. If you saw my yard you would understand. Cub offered a kit for the 44 and 50 inch decks used on the 1650 and similar model tractors. Although not made for the 48" deck the PO of my tractor installed them.
Meanwhile my question has not been answered. Does Cub recommend they get installed in line with the rear wheels? Putting the wheels on a deck for my son who has hit stuff and pushed the front of the deck in.
Old 03-04-2019, 07:58 PM
There is a service bulletin on the installation of those wheels and brackets for a 44c, maybe you can goooooogle it.
Old 03-04-2019, 08:09 PM
mortten mortten is offline
I cut a set off of a rusted deck and put them on a good shell. They do line up with the back wheels. I took the skids off. There’s a NOS set on flea-pay right now, 759-3253.
Doug
QA-36A
42" blade
Old 03-05-2019, 09:57 AM
Thanks for the info. I got a pair of used ones cut off a rusted deck as you did. I did find a listing of the service kit with instructions, but the resolution makes it hard to be able to read the installation location dimensions. I thought they should be in line, but wanted to make sure. Thanks again for the help.
Old 03-05-2019, 12:37 PM
I bought an OEM kit, complete with wheels, brackets and instructions as shown many years ago. Still have it somewhere as I never used them. If you need additional help, let me know and I'll dig them out.
Old 03-05-2019, 01:30 PM
Yes, it would be nice to have a good photo or scan of the instructions to verify location. I would think the wheels should line up front to back as mortten has posted.
Old 03-05-2019, 04:44 PM
Scroll down to post #28. This is a 44" deck with the wheels factory installed.
https://www.tractorbynet.com/forums/...-2544-a-3.html
Old 03-16-2019, 01:16 PM
A seller on ebay was kind enough to scan the instructions and provide a very readable location dimensions for the brackets.
