Old 05-26-2010, 08:53 PM
bvanzalen's Avatar
bvanzalen bvanzalen is offline
Default PTO on 169
My clutch brake fell off while changing belts the other day. From reading the diagrams, I lost the washer and the ring retainer which clips onto the thrust button. The thrust button is still in place but I see no way for a clip to attach.
The diagram here http://www.onlycubcadets.net/forum/showthread.php?t=9 does not show the thrust button detail. (I have type B with brake)
What am I missing guys?
Bob VanZalen
1974 Cub Cadet 169
Old 05-26-2010, 10:51 PM
My 169 has the same set up. The end of the button has been worn away over the years. last time i had it apart there was barely any groove left for the snap ring. I am sure its getting real close to letting go also.
Old 05-27-2010, 06:11 AM
bvanzalen's Avatar
Any problem with leaving it the way it is Diz? What's involved in replacing the button?
Bob VanZalen
1974 Cub Cadet 169
Old 07-20-2010, 01:11 PM
hydrocub hydrocub is offline
Talking
your parting with about $9.00
Old 07-20-2010, 11:13 PM
Hey bvanzalen Sorry i missed this when you asked a question. Don't know if you still need help or not but you would have to disassemble the P.T.O. to replace the button. I just switched my 169 over to the early style button and changed from the brake style lever to the wear button lever. here are a few pictures to let you see what you would be getting into.
This is just putting the P.T.O. back together. Getting it off and to this point was a bit of a fight.
Once everything is apart you are just starting with the pulley.
Add the springs, making sure to line them up as shown.
Then the thrust button. This is the early style. Yours would have the nub sticking up with the groove for the snapring.
Then the levers and bolts. Then it gets a little tricky. You have to grab all of this and keep it together while you turn it over.
This is what it looks like when it is flipped over.
Then add the clutch disc.
The 3 release springs.
And the pressure plate.
You have center the clutch disc and line up tabs with the set screw holes.
Then this is the way i hold it while i adjust the tension on the springs.
You just barley snug the vise just enough to keep the nuts from spinning. This way you are not trying to hold everything together, keeping the disc centered, and trying to hold a wrench all at the same time.
This is what it will look like before you start adjusting.
Then you just bring them down a little at a time till the gage just touches the same in 3 positions.
If you get a rebuild kit it has good directions. but you get the basic idea here.
Hope this helps.
Old 07-20-2010, 11:46 PM
Diz Jr. Great pictorial!
Wish I had that when I did my first pto rebuild.
Old 07-21-2010, 03:27 AM
Great pics Diz! Thanks for sharing them!
Old 07-21-2010, 09:34 AM
thanks Diz ...good pics , and I like the vice idea....I use a vice to press
out spirol and drive pins...comes in handy huh
Old 07-21-2010, 09:42 AM
bvanzalen's Avatar
Excellent job Diz. Thanks!
Bob VanZalen
1974 Cub Cadet 169
Old 07-21-2010, 12:09 PM
Excellent pics, Diz! Thanks for sharing them.
