Old 11-10-2018, 06:11 PM
hogfly hogfly is offline
Default 1863
i dont use my 1863 much but start often was using it today to pull trees went to put it away and when it gets on a pull it starts surging and cracking if you pull choke out a little it helps very little once it starts doing it it even does it idling any advice what to check helps thanks kenny
Old 11-10-2018, 06:24 PM
RLause's Avatar
RLause RLause is offline
If you would use punctuation your post would be easier to read.
Richard
Old 11-10-2018, 07:52 PM
cooperino's Avatar
Not sure what you mean by cracking but If you need to pull the choke to make it run better chances you have a fuel or air restriction. There could be junk in the carb or fuel lines and or tank. I would start by checking fuel system.
Old 11-10-2018, 08:15 PM
TNTs CC TNTs CC is offline
I think you may have meant vacuum leak instead of air restriction.
I' have no idea what he means by cracking either.
3240 870hrs - 48" 289 deck, front hitch, 3 hyd circuits, 54" blade w/hyd angle, 45" 2-stage snow blower, Sims cab, 5 42# suitcase weights and 70# rear wheel weights
GT3204 207hrs - 48" 289 deck, 45" 2-stage snow blower, 54" blade and angle cylinder
3204 580hrs - 48" 289 deck - Parts Tractors - 3208 560hrs (rusty) 3 hyd circuits, 3pt hitch, 44" deck - 3165 rust free roller
1650DH 54" blade, Xtreme cat-0 3pt, 44" deck, filled 23x10.5-12 Tru-Powers
Old 11-11-2018, 07:15 AM
Default 1863
ok sorry guys lets try again. start tractor cold,no problem it will set and idle fine,rev up and down ,no problem when you start moving it (on a pull) the engine starts surging (revving up and down) back firing trying to cut off. if you slightly pull choke it helps enough to get back to shed but still does it. and when i get it back even at idle it still does it hope this explains it better thanks kenny
Old 11-11-2018, 08:16 AM
Rmowl's Avatar
Rmowl Rmowl is offline
Pulling out choke to make it run better is indicative of a carb issue. Take off and clean or rebuild. Will have to remove manifold. Be mindful of the gaskets. Good time to clean up the engine
-Rick
IH 782
IH 126
CCC 1863
Old 11-11-2018, 09:53 AM
bugeye bugeye is offline
Are both fuel tank valves fully open? On my 1864 when the fuel tank was low, the engine would want to surge, die under load. I was using only the left tank valve and it was major plugged. I removed fuel tank, cleaned tank and both valves, replaced complete fuel hose and fuel filter. No further issues.
If your fuel system has never been serviced, it's due.
1863, 1864, 48" and 54" mower decks, 54" snow plow, 451 snow blower, TracVac 580
Old 11-11-2018, 10:33 AM
Default 1863
yea both vales open.i use stabill in all my gas. letting it run out now to put in new.sprayed carb cleaner in it seemed to help for a little while, Governor on and off causing surge and wont idle at low rpms.
Old 11-11-2018, 10:42 AM
twoton twoton is offline
Dirty fuel system.
Old 11-11-2018, 11:00 AM
Default 1863
just ran it out of fuel,pulled filter, shut both valves on tank open 1 blew it out closed it opened other blew it out,then filled with new fuel opened them individually had good flow from each going to get new filter and plugs. will holler back thanks guys
