Old 11-11-2018, 04:07 PM
danman danman is offline
Default 2182. hydro fluid?
my new used cadet needs tranny fluid. no clue what prior owner used. any advice what to use to top it off? thx
2182 super
Old 11-11-2018, 09:03 PM
This is my suggestion. Since you have NO knowledge what is in there, then you have two options. (A) Top it off with your favorite Hydraulic Fluid and run a "cocktail" mixture, or (B), drain it all out, change the filter, and put what is recommended.... See Link: Hydro Fluid
Old 11-12-2018, 04:53 PM
taylorjm taylorjm is offline
I know lots of people here have used the tractor supply Traveller Universal Tractor Trans/Hydraulic Fluid. When I changed my oil 3 years ago I used it and haven't had any issues. It's supposedly compatible with hy-tran, but I wasn't mixing old with new either. It's not really transmission fluid that you need, it's a hydraulic fluid since you don't really have a transmission, you have a hydraulic pump. https://www.tractorsupply.com/tsc/pr...l?cm_vc=-10005
