Picked up a new to me(obviously) 122 this week and it starts and runs great. - sort of.
Using it to pull a little swisher rough cut mower today which should be cake for it. But whenever it’s under any stress (like going up a hill)in second gear, it lugs, acts like it’s going to die- and sometimes does. In first gear it does OK. Third gear is out of the question. On flat land, it does fine in all the gears. When it dies, I have to wait a minute to crank it back up. Makes me think it’s a Fuel supply issue. I’ve adjusted the carburetor and even swapped it with a known good one off my 126 and it still acts the same. Going to replace the fuel filter tomorrow, but what else should I be looking at if that’s not a magic bullet? Thanks. Jbo |
Hate to ask but does it have enough gas in the tank?
Pull choke and see if it picks up any when issue occurs, if so it’s a fuel supply issue. Maybe tank or sediment bowl screen clogged? How is the governor adjustment? Top rpm 3600?
Excellent question. Plenty of gas. Choke has zero effect.
Jbo |
I’m thinking if the filter is clogged, the choke might not matter much ‘cause it’s not getting fuel anyway.
Thanks. Jbo |
It came from the factory with a sediment bowl. That might need cleaning.
Somebody’s removed the sediment bowl along the way. Just a little pancake style filter now.
Jbo |
The thread coming out of the tank is 1/8" NPT Jeff |
Clogged filter? Shut-off valve open all the way? Remove the line from the carb and allow fuel to flow into a container. Make sure you good flow.
149, 2072, Original, 1772, 1782, #1 cart, Parker 48" sweeper, |
I have good flow from the filter. (Added a shutoff so fuel briefly went everywhere.
![]() Pardon my ignorance, Jeff, but what’s the advantage of a sediment bowl over or in addition to a fuel filter. Seems to me a fuel filter would be a reasonable replacement for a sediment bowl. ? Thanks for all the feedback. Jbo |
