Old 08-19-2018, 03:57 PM
Bamafan Bamafan is offline
Inactive Member
Default Key switch for 100
I'm finely back to working on the 100 restore that I posted some months ago, After some very serious back surgery and lots of not doing very much at all, I'm finely able to stand and walk for short periods.
Anyway I have been ordering needed parts, I have a question about the key switch. Will any 2 pole key switch work. Cub cadet shows one but, $49.97 plus shipping is a little stiff for me.
When I get things going again on the 100 I will revive the original post.
Thanks Larry
[B]Larry[/B]
Old 08-19-2018, 04:07 PM
Yes, $50.00 seems a bit excessive. If PC is not a concern, any On/Off key switch will work. Indak 2A431A will work.
Old 08-19-2018, 04:19 PM
Inactive Member
Thanks Roland I kinda thought would, but wanted to make sure, and thanks for the part number.
[B]Larry[/B]
Old 08-19-2018, 05:04 PM
Get a true IH key switch. Or, what I mean is a switch that uses the original IH key. You don't have to pay $50 for one.
https://www.tractorpartsasap.com/ign...op-113393.html
https://www.steinertractor.com/IHS76...F=120613A3BA8D
Old 08-19-2018, 07:52 PM
Inactive Member
Thanks Jonathan for the info.
[B]Larry[/B]
Old 08-20-2018, 11:41 AM
Stephen.Mellish's Avatar
Stephen.Mellish Stephen.Mellish is offline
If you are not too concerned with correct, you can use any single pole (on/off) toggle switch as well.
It doesn't prevent anyone from starting the tractor, but it will work the same as the key switch. You may need to use washers to make it fit the hole, but no cutting or anything else required. Under $10.
The Collection, so far: Cub Cadet 100(x2), 125(x2), 123(x2), 70, 71. Adding more when I can find them.
Old 08-20-2018, 06:43 PM
Inactive Member
I'm trying to put the tractor back as original as possible. But thanks for the response.
[B]Larry[/B]
