Old 07-01-2018, 08:59 AM
Cambria cub Cambria cub is offline
Default Spring assist
Was thinking about getting one for the128. Was wondering if it would be worth it do they make a noticeable difference.
Old 07-01-2018, 09:19 AM
twoton twoton is offline
For what implement(s)?
Old 07-01-2018, 10:09 AM
For 42 inch blade
Old 07-01-2018, 10:14 AM
I put one on my 1200 as I plan on adding a tiller. What I found is I am not happy using it with a front blade as it reduces the down pressure.
Old 07-01-2018, 10:19 AM
I see with the tension on it would not let blade drop to well?
Old 07-01-2018, 10:28 AM
I find myself pushing the lift lever forward as I push snow to try and scrape down to the gravel. I could reduce the tension on the spring a bit to try and find a balance but for me I feel that it is unnecessary for a front blade.
Old 07-01-2018, 10:39 AM
Ok I will keep that in mind. Thank you
Old 07-01-2018, 11:23 AM
Pushing down on the lever will do no good, only give you a little bit of exercise is all if the lock out pin is not in place.
Old 07-01-2018, 11:25 AM
athomas's Avatar
athomas athomas is offline
Definitely a plus , helps the deck to float better when it needs to and definitely saves saves your arm when doing work with a blade, I would not want to be without it !! Set the tension properly and it should not be an issue ! I found if scraping ice or dirt with a blade gotta push down on the handle with or without the helper .
Old 07-01-2018, 11:39 AM
Just wondering after moving a pile of gravel a week ago. Thinking it's a lot of work on the old arm maybe spring assist would help when it comes to plowing snow
