I got the engine out of the scrap yard 1440 and it has a broken connecting rod. The engine got some water in the one cylinder which rusted the bore a bit, I don't really have anything at home to clean it up with but I suspect it would need bored. The crank doesn't look bad but I can't get a good look at it since it's still in the block and I don't have an impact here to get the flywheel nut off. Are these engines worth rebuilding? I've found .010 pistons new and plenty of good used parts.
I would say so. I think that is a 16hp if you take the restrictor gaskets out of the exhaust. Sam loves the Vanguards! I really like the 23 in my Super.
Travis 1993 Cub Cadet 2064 1988 Cub Cadet 2072 1980 IH Cub Cadet 782 w/CH20 1966 IH Cub Cadet 102 w/K301 1961 IH Cub Cadet O 1967 IH Cub Cadet 102 & 122 JD 2155 w/ 175 loader |
Still looking for opinions.
Here is an option......
![]() http://www.smallenginewarehouse.com/...1440-Category/ Can probably find a running 1440 cheaper than the new motor. Did you just want the motor for another project? You will need to push the pencil on the parts to see if it is worth it for what ever end result you want.
http://www.onlycubcadets.net/forum/s...ad.php?t=42646 70, #1 cart. Brinly Cultivator. Some wheel weights . {125, 126, 2072-Sold~regrettably, 2284 60 inch Haban 325 deck., 451 snowblower, 2182-60 inch Haban 374 deck- "Money Pit", 401 Haban 54 inch dozer blade- rebuilt, 1440-down the road, Another 2182 for parts. Another 2284 for parts. 450 blower. 1812-sold, 2072 w/ Haban 374, and a 2182#3 w/ Haban 325}-------> All SOLD |
I was hoping to use the engine to repower a different tractor. I'm gonna get the crank out one of these nights so I can get a good look at it and go from there. Pistons are about $90 each and I found a complete gasket kit, depending on the condition of the crank I could rebuild it for about $500.
