Old 04-30-2018, 04:12 PM
mkedzierski's Avatar
mkedzierski mkedzierski is offline
Default Wheel Weights for 23x10.5 Tires Cub XT3
Can anyone tell me what wheel weights will fit on the 23x10.5 tires that are on my XT3? I don't know what to measure and cross reference when I do a search online.
Old 04-30-2018, 06:48 PM
They do not show wheel weights, only a rear weight bracket, but if the wheels have the 4 holes in the rim, I do not see why not.
If it is still under warranty though I would check with the dealer, to be sure.
Old 05-01-2018, 02:22 PM
vr4Legacy's Avatar
vr4Legacy vr4Legacy is offline
My dad just got an XT3 and it came with wheel weights from the dealer. I don't have any more details, but you can put weights on them. Looking at the pics it looks like they sit inside a lil, so they are probably standard wheel weight.
Check with your dealer, I'm sure they can get you a set. Might not be Cub Cadet, but weights are weights.
-Jason
Cub Cadets: 1200 | 149 | 1650 | 122 | Z-Force S 54
Implements: QA42A | Push Blades | #2 Tiller | Rear Blade | 223A Utility Trailer | And a few mower decks
Gravelys 5260 | CI Walk-behind (Project)
And a couple of Subarus
Old 05-05-2018, 03:06 PM
I just measured the rims and the inside diameter is 10" and the hole spacing for mounting them is 8 1/2". Other than that, MTD doesn't give you what size rims they'll mount too.
