Old 04-23-2018, 05:54 AM
bcherup bcherup is offline
Default LT1045 issue
Hey gang just reaching out for some assistance. Recently had the drive belt break on me, no big deal, put new one on and everything should be fine right? Well this is where the issue lies. Once I got the new belt on this thing barely moves. It .oves at a slow creep and will not go up a hill. You have to feather the throttle to get it to move. I've had this thing in the air while running all the pulleys are free spinning. Any ideas or guesses?
Old 04-23-2018, 06:29 AM
dale c. dale c. is offline
wrong belt ? too long ? not routed on the pulleys correctly? the lt 1045 takes different belts depending on the year / vin. # ...also the tensioner spring may have came unhooked when the belt was off . is the belt tight with the pedal up ?
Old 04-24-2018, 06:49 PM
Pulleys are free it was indeed correct belt I double checked before purchasing. I did locate a rod with a threaded adjustment nut that connects to the gas/reverse pedal. Springs appear to be in good shape. Belt not tight with pedal up. Nothing appears out of place spring,pulley etc. It is a 2005 serviced regularly. Just trying to troubleshoot it before I have someone tell me it may be hosed.
Old 04-24-2018, 08:33 PM
Bamafan Bamafan is offline
Inactive Member
I would bet you have the wrong belt. You still have the old belt? If so put a tape measure on it. and then measure the new one.
[B]Larry[/B]
Old 04-25-2018, 07:30 AM
the belt should have tension when the pedal is up , otherwise the belt will slip
Old 04-25-2018, 10:43 AM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
Originally Posted by bcherup View Post
Pulleys are free it was indeed correct belt I double checked before purchasing. I did locate a rod with a threaded adjustment nut that connects to the gas/reverse pedal. Springs appear to be in good shape. Belt not tight with pedal up. Nothing appears out of place spring, pulley etc. It is a 2005 serviced regularly. Just trying to troubleshoot it before I have someone tell me it may be hosed.
You should not have to adjust that.
You might have received the wrong belt even if the numbers printed on the belt match the old belt. Mistakes happen in production too.
Measure total length of both belts to confirm same length.
Confirm same width and shape while you are at it.
If those check out to be the same, double check the belt routing.
