Title says it all! Put the new driver and clutch in, mowed awhile. Then started rattling, then louder next a big you know what'n BOOM! Guess I had the clutch adj up too tight. It destroyed one pin on the driver, the new clutch, throw out bearing, teaser spring, the clutch arm and who knows what else. Was all my fault. I should have triple checked the clutch adj. Now I have an expensive mistake/lesson learned!
Brian April 1979 1200 Quietline 44A deck 1988 1211 customized into a 1288 with a K301AQS 38C deck and a 1864 54” deck . Snow blades 42" and 54" . Brinly disk, brinly plow a cultivator and a $5 brinly yard rake! ![]() |
Here is another picture
Ouch. That hurts.
Ouch.
So you think the clutch arm was riding on the throwout bearing and not enough play in the pedal? I want to make sure i avoid this happening to me...
-Jason Cub Cadets: 1200 | 149 | 1650 | 122 | Z-Force S 54 Implements: QA42A | Push Blades | #2 Tiller | Rear Blade | 223A Utility Trailer | And a few mower decks Gravelys 5260 | CI Walk-behind (Project) And a couple of Subarus ![]() |
Wow, sorry to hear that.
![]() Quote:
Yes the throw out bearing was riding the clutch arm. I was thinking of replacing the arm and hanger. Now I don't have a choice! I just hope that the driveshaft is ok. Have to make a new pin for the driver. All it is, is a grade 5 bolt with the head cut off. And ground smooth.
Man, that's a bad set back.
Well that sucks. This clutch has been fighting you. Hope you get it figured out.
could have been worse,with the gas tank right above those spinning parts
![]() Quote:
I don't understand how riding the clutch with a tight adjustment could cause this. I can see the disc wearing because of slipping but not a catastrophic failure like this. Can someone explain why this happened? |
