Old 01-16-2018, 06:47 PM
Chardie Chardie is offline
Default Creeper drive
I have a creeper that came off a parts unit I bought for restoring my 122. It was full of water when I removed it. The shift fork is rotted along with the shaft. Obviously I’m going to rebuild it but I’m not sure if I’m disassembling correctly. I removed the large snap ring from the engine side and it seems that everything should come out that end. It moves with gentle tapping but won’t come apart. I don’t want to break it. Also is there an advertiser here that would be best for parts. Thanks
Old 01-16-2018, 07:23 PM
All chassis service manual for the tractor series have the repair info for the creeper. Download the manual for your tractor.
If you don't know where to find it, here it is:
http://www.onlycubcadets.net/forum/s...ead.php?t=4641
I don't know what parts you need, or if you do either. If you just need gaskets and seals, get the seals at a local bearing or parts store. You can make the gaskets. Bearings, again source locally. If the shifter lever needs repaired, member Jeff in PA on this site makes parts. If the gears are bad..... buy another creeper. By the time you find and fix it, you could likely have bought another one.
Old 01-16-2018, 07:41 PM
twoton twoton is offline
Originally Posted by Chardie View Post
.....parts.....
http://www.onlycubcadets.net/forum/s...081#post440081
Old 01-16-2018, 07:46 PM
Originally Posted by twoton View Post
$40 for $15 worth of parts??? Glad he can make money.
Old 01-16-2018, 09:24 PM
Thank you for the information.
