Old 07-10-2017, 10:23 PM
zcub22 zcub22 is offline
Default Model 149 Hydro Release Lever
Hi All. I'm putting a new bracket on the release lever on a 149 hydro. The bracket is held to the lever with a roll pin but is there something else that keeps the lever in place like a spring when the lever is engaged? Otherwise, it's just loose.
Old 07-10-2017, 11:20 PM
Not really, the "flapper" is spring steel , the lever has to be held while pushing the tractor.
Most ppl just install the automatic release valves, once the manual release ones start leaking, thus eliminating the need for the lever & flapper.
Old 07-10-2017, 11:38 PM
Thanks, George. I think the auto release valves would cost quite a bit more than the bracket did.
Old 07-11-2017, 12:00 AM
Yes they would but when the manual ones leak, and they will, then you can update unless you are going to have the manual ones rebuilt, or wanting to stay original as possible.
