Our 1210 Hydro working great - can't believe how much better it cuts than our previous JDs - until today. Mowed for an hour & suddenly engine stopped. Put in a new battery about 2 months ago, along with a new voltage regulator. Had a motorcycle situation a couple of years ago - bad coil. Would be riding & engine would cut out. Waited a while while the coil(s) cooled down, then could restart the bike. Noticed the same thing w/ the 1210 - let it sit a while & then it starts up again. Sound like a bad coil? Thank you in advance!
Get a spark tester and run the tractor again till it dies and then put the spark tester on to confirm a bad coil. Sounds like a bad coil but that's alot of work to go through and not be 100% sure.
Does it have an external coil and points?
Then you can test the coil, most times when the key is left on they get cooked and go bad, it gets a rounded bottom on the coil.
Good point Lew, i forgot the early ones didn't have a magnum like mine.
Tim & Lew,
Thank you for your reply. Our engine is the Kohler Magnum 12, which I understand has solid state ignition (no points?). Does that make any difference? Thank you! |
On the magnum the coil is under the blower housing so the engine will need to come out to replace it, that's why I suggested getting a spark tester and running the tractor till it dies to confirm you're loosing spark.
Tim,
WOW - engine has to come out?? (and I just learned where the engine oil plug is). This is something waaay beyond my pay grade! Frankly, if it weren't for you guys I would never have heard of a spark tester. And thanks to google & youtube, now know what one looks like & how to use it! Thanks again! |
Where in PA are you located?
Tim,
In West Chester. And got to try out my new spark tester when tractor died while mowing. NO spark. Does that mean a bad coil - or is there something else I can test? Thank you! |
It's bad. Removing the engine is pretty easy, unhook the wires and cables attached to the engine and then remove two nuts from the driveshaft coupler and the 4 bolts holding the engine to the mount and it will lift right out. It can be done in under 15 minutes by experienced hands.
