Old 09-12-2016, 09:05 PM
coinman66 coinman66 is offline
Default 44A deck spindle question
Can the bearings be replaced in a 44A deck spindle? It's on a 1250 model. If so is there any tricks or tips to do so?
Thanks
Old 09-12-2016, 10:03 PM
Yes.
Take it off, disassemble, replace needed parts, reassemble.
Old 09-12-2016, 10:33 PM
Yes.
Happen to know the bearing size or part number?
Old 09-12-2016, 11:27 PM
DeltaCub's Avatar
DeltaCub DeltaCub is offline
The original style bearings were ST-745. It is an integrated bearing and spindle assembly....a water pump style. A newer style is available from Cub Cadet, but you can find the original style from some dealers and online. Easy to replace. Make sure you check the housings carefully. They get beat up after 40 plus years and the bearing assembly can be loose.
Queen Of The Quietlines!
Old 09-13-2016, 06:21 AM
That information is located in our Technical Library Section for Implements. See.... Mower Decks
