Old 08-31-2016, 12:28 PM
DieselDoctor's Avatar
Default Engine cradle modification
I plan on pulling the K321 Kohler 14hp out of my 147 in the near future to rebuild it. It has developed a rod knock. The Cub is new to me and I have no history on it. My question - could someone please explain the engine cradle modification I've heard mentioned several times as being done by others? I looked in the technical section but was unable to find anything posted. I'd like to put this back together with improvements if possible. Thanks!
Old 08-31-2016, 12:40 PM
Leadslingingdaddy's Avatar
I believe that Mod is for the QL model....Yours should be hard mounted to the frame....
Old 08-31-2016, 01:01 PM
Thanks for enlightening me. So much to learn!!!!
Old 09-02-2016, 05:18 PM
vr4Legacy's Avatar
vr4Legacy vr4Legacy is offline
Yes, it is a quietline only mod. They used "floating" rails on rubber iso mounts to quiet and smooth out the engine.
If you're curious, here is a link to the mod.
http://www.onlycubcadets.net/forum/s...ead.php?t=4630
-Jason
Cub Cadets: 1200 | 149 | 1650 | 122 | Z-Force S 54
Implements: QA42A | Push Blades | #2 Tiller | Rear Blade | 223A Utility Trailer | And a few mower decks
Gravelys 5260 | CI Walk-behind (Project)
And a couple of Subarus
