Old 07-29-2016, 10:57 AM
Wayne Wayne is offline
Default 108 carb
My machine ain't running so good. It will start but will not run for long and definitely seems like a fuel issue. I can't quite get it up to full idle speed (and there's a trace of dark smoke) so as soon as I engage the mower deck it bogs down. I pulled the air filter and noticed gas droplets leaving the throat. Is it time for a rebuild, or are there things I can try short of that?
Cub Cadet 2166
Old 07-29-2016, 11:08 AM
I would start with a carb rebuild.
Old 07-29-2016, 11:31 AM
Merk Merk is offline
Along with carb rebuild check the throttle shaft for play.
Project Uncle Dick
Cub Cadet 70
Old 07-29-2016, 05:19 PM
Sounds to me like it's sucking air someplace.
Old 07-29-2016, 05:23 PM
RLause's Avatar
RLause RLause is offline
Sounds to me like it is too rich. Try turning the main jet in a quarter turn.
Richard
Old 07-29-2016, 05:32 PM
2 votes for carb rebuild
1 vote for too lean
1 vote for too rich
Sounds like a tie.
So.... who do you believe??
I'd rebuild the carb, just so you know what my opinion is.
But hey, I'm just another vote right??
Old 07-30-2016, 02:01 PM
I also vote for the rebuild, plus you might as well clean out the tank and lines while you are in there!
Randy
2 original cub cadets
1 100's
2 149's
1 73
1 2182
Old 07-30-2016, 09:36 PM
Randy
Well, that makes 3 for the carb rebuild. I've also become aware that I have no inline filter, and I probably should rectify that.
Cub Cadet 2166
Old 07-30-2016, 10:11 PM
i don't run an inline filter on my 108, the tank has a screen in it and as long as everything is clean it shouldn't be an issue.
Old 07-30-2016, 10:28 PM
sawdustdad's Avatar
I ran my 108 for over 30 years with no inline filter. Rebuilt the carb every 7-10 years or so. Bi-weekly 2 acre grass cutting machine. Most of that was with non-ethanol fuel. Nowadays, ethanol fuel really messes with anything that's not in constant use.
