My cub 129 will start and run great till after about 20 mins of mowing then will not stay running till it cools off any ideas?
Sounds like the coil is going bad.
Ok, do I have to buy the one from Cub Cadet, or can I get one from the auto parts store?
You should be able to get one from the auto parts store.
Ok, awesome I've got one. I bought for it a while back, I'll try that one.
Just wanted to double check that it would work
Make sure it is the correct coil. You need a 3.5 ohm coil. Between 3 and 4 ohm is fine.
I had this issue once on my 122, ended up being the condenser. Switched in a new one, problem solved.
Make the best of each day , Todd ![]() Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! ![]() |
Thanks all its got a new condensor on it and put the new coil on tonite well see how she does tomorrow
