I put the part number in the description just incase I'm not calling it by it's correct name. Does this simply pull off or is it screwed on there? I removed the nut that was in side this but just did not want to start beating on this thing till I understood how it comes off. I do have a pulley puller but the center bolt that comes with it is not long enough to push against the shaft and tighten the 3 arms that wrap around this part. I'm also posting a pic of the item to make sure I show you what I'm talking about
108 upgraded to 12hp 127 with all the trimmings 73 WIP 75 WIP Blade, blower, decks Tons of left over parts ![]() |
Unbolt the center bolt (like you did) and pull it off.
![]() There is a dowel pin that holds it from turning. They get stuck on the dowel. Sometimes they are hard to get off. DO NOT use a puller. It's alluminum, you'll break it. Probably have to take the tins off and get behind it with a screwdriver or small pry bar. Why are you taking it off? |
It is snug but should pull off. Here is a picture of the back side.
The small hole is for a pin that also goes into the flywheel. When you get it off the pin may stay in the flywheel or it may come out with the hub. |
![]() Quote:
Ah. nice pic and helpful. Thank you
Another tool for Jeff to make,just a piece of flat stock with three holes in it,two to bolt it to the pulley using the existing holes,and one in the center that would be tapped,and a long bolt with a tit on the end. I like that word.... Bolt!!!
Instant drive puller.
![]() Quote:
Sometimes they can be really stubborn to get off, don't try to force it or pry on it too much. I have been known to tap them back and forth using a hammer an a piece of wood, gentle taps...
![]() Quote:
So are you saying taping it on the sides? I can't really get behind it because of the heat shield. Sucker won't move
