Well then I went drove this thing around after figuring out the wiring issues. I found the tractor goes faster in reverse then forward but I try to adjust linkage and nothing changes. I also see that the valve on right side as you sit in Seat has a slight leak. could that cause my problem.
What would happen if you were to swap the valves left to right and right to left?
1989 - Cub Cadet 1772 1987 - Cub Cadet 1572 w/Rear PTO & Cat. 0 38" Lawn Sweeper #196483 42" L42 (Bush Hog) Rotary Cutter # 190349 45" 2-Stage Snowblower # 196364 48" Haban Rotortiller Rear PTO Driven #190356 54" SnowBlade with hydraulic Angle #196376 60" Haban Mowing Deck #196374 |
Has the pump been apart?
haven't swapped them yet. sam I don't now if it ever been a part I got it second hand from one of the guys on here and he took it to a shop to be checked and they said it was good pump. but I don't know if they took it a part. I know that they put one seal in it and it the out side one on input shaft for discharge pump SU-9008000-6201 part number and number 27 on look up sematic.
Thinking the same thing Sam. Sounds to me like the swash plate got put in 180*out.
149,682,1641,1711 with a 12hp in it 1 8" brinly plow 1 10" brinly plow 451 snow blower,H-48 International snow thrower 42" york rake with fold down grader blade. |
If they changed the trunnion seals as Kelly said they may have put the swash plate in up side down. The swash plate has a lug on the back side to limit how far it moves in reverse. Upside down would limit forward.
I never had one a part. how much fun is to take it apart. so is any way to tell for sure with out taking it a part
Will the lever travel all the way in the dash slot? Or does it just stop?
Only goes 3/4 up the slot maybe in forward and reverse goes alway end of slot
Pretty sure someone was inside that pump and put the swash plate in upside down. Read up on how to rebuild the pump. The info is in the service manuals for most of the hydro tractors. It's not all the difficult to do just take your time and make sure every thing is absolutely clean.
