I have a 1572 with a broken transmission casting. Can I take a rear out of a 1711 or 1811 and put it in the 1572?. If so do I have to use the 1572 pump and will pump bolt right up to the 1711/1811 rear?
Nope, gearing is different between the GT's and the Supers. Post some pics of the problem on your 1572 and I'll try to offer suggestions.
Easy fix. Go to Xtreme
http://www.xtrememotorworks.com/Part...ts%20Hydro.htm Order this, bolt it on and be a happy camper. CC-99-001 $130.00
You can use The front haft of the rear end from 1811. That what I did .
Believe that little hole there at the brake will leak correct? I think it would be easier just to buy used rear then rebuild this one down the road. It's been sitting outside with rear cover off and one axle off for 2 years.
On the up side I'm pretty happy I got it started today after sitting for 2 years outside. No power from key to starter (screw driver to jump starter) but key powers everything else up. The small red wire on starter is not getting power. |
![]() Quote:
![]() Quote:
Either way... good luck with your project!! ![]()
Jay 40 years of Using and playing with IH Cub Cadets! Proud owner of the following: Cub Farmall, Super A Farmall, Original, (2)70's, 72, 100, 102, 123, 105, 125, 127, 108, 128, 1450, (3)782's, Yellow 982, 1782, "Sam's" 2182, M Farmall and a #7 trailer |
