I broke the roll pin in the clutch on my 1572 over the weekend. It's item #10 in the diagram below. It's part # 710-3035 .25" X 2.25" and of coarse it's NLA.
Does anyone have a good lead for a replacement pin. I know It needs to be a coiled roll pin and I think there also hardened. I found some pins at McMaster-Carr in the link below, but I'm not sure if there's something else out there I should instead of these. http://www.mcmaster.com/#95755a429/=10180nn ![]()
1450 w/ 44gt deck, 1572 w/ 50C deck, 450 snowblower. |
The McMaster pin should work just fine. You may need to shorten it. A cut off wheel in a die grinder works well for that task. For what it's worth most people remove those clutch's and just go to a solid drive shaft or up grade to the CV style. I'm sure Oak will be along with more info.
![]() Quote:
I have thought about removing the clutch, but I'm worried about getting the tractor to start in the cold. I know my 1450 has a real hard time turning the hydro when its below about 20°. If I didn't use it in the winter, or lived down south I would remove the clutch in a second.
![]() Quote:
![]() Quote:
1989 - Cub Cadet 1772 1987 - Cub Cadet 1572 w/Rear PTO & Cat. 0 38" Lawn Sweeper #196483 42" L42 (Bush Hog) Rotary Cutter # 190349 45" 2-Stage Snowblower # 196364 48" Haban Rotortiller Rear PTO Driven #190356 54" SnowBlade with hydraulic Angle #196376 60" Haban Mowing Deck #196374 |
CV style? Tell me more please.....
Read this thread, start at post # 83
http://www.onlycubcadets.net/forum/s...t=41407&page=5
Don't know why you guys cant see the link, works for me.
![]() but here it is again http://www.onlycubcadets.net/forum/s...t=41407&page=5
