Old 09-29-2015, 10:29 AM
Wallknight Wallknight is offline
Default 982: How do you fill hydro fluid? Keeps burping.
I tried to fill up the hydro on my yellow 982. Dipstick right behind the battery under the seat. Apparently, there's 2 types of these; mine has the elevated fill tube. Anyhow, using a funnel, whenever I pour a little bit of fluid in, it covers over the small hole, and moments later the machine releases a big burp, spewing most of the new fluid out, all over the machine. Any more than a tiny drip gets puked out. with a 2 gal jug, that's not easy. Is there a secret to doing this with minimal spillage?
Old 09-29-2015, 10:32 AM
jimbob200521's Avatar
Stick your funnel in the fill hole, take a small tube and feed it through the funnel into the rear making sure to leave some sticking up above the funnel. This allows the air to escape from that tube and your fluid to go down unimpeded.
-Ryan
Old 09-29-2015, 04:22 PM
CadetTommy's Avatar
CadetTommy CadetTommy is offline
Just go as slow as you can, and use a funnel. Other than that not much you can do.
'74 IHCC 108 - 38A, supersteer axle
'75 IHCC 1000 - 44A, Sears wheel weights
'87 CC 1872 and 1811 - Haban, 44C
'96 CC 1863 - 54GT
'79 JD 400 - 60" deck
"Projects" '67 123, '65 102, '71 126
Old 09-29-2015, 04:26 PM
This is normal then?
Old 09-29-2015, 04:30 PM
aagitch's Avatar
aagitch aagitch is offline
Yes. I have removed the access cover to the hydro release valves and removed one of them just enough to prevent the famous burp.
Adrian
2072 (789513)
Old 09-29-2015, 04:42 PM
CadetTommy's Avatar
Perfectly normal, and extremely annoying.
'96 CC 1863 - 54GT
Old 09-29-2015, 04:52 PM
It's normal but there's also a way around it, see my above post
-Ryan
Old 09-29-2015, 05:01 PM
j4c11's Avatar
j4c11 j4c11 is offline
You sir are a gentleman and a scholar, excellent suggestion!
Old 09-29-2015, 09:40 PM
red56turbo's Avatar
When using a funnel, offset it so it only covers half of the hole. Don't push it down in the hole. You will have to hold onto it. This works by letting hytran run down one side while letting air escape as needed. This process has worked for me. Takes awhile, so patience is a good thing.
Josh
Diesel Cub Cadets...........
Old 09-29-2015, 10:00 PM
PaulS's Avatar
PaulS PaulS is offline
I have used the small tube through the funnel and it works so much better than getting a face wash from the annoying burps.
Tags
982, fill, hydro
