Hi, my 124 won't turn over. Starter generator checks out ok as well as coil and points. Battery is two years old. Bare wire somewhere maybe? Checked safety switch, it engages. Thanks for any info
-Rick IH 782 IH 126 CCC 1863 |
Not enough information.
Coil and points have nothing to do with the cranking system. How about the solenoid? Is it working???? |
Ignition switch?
My first suspect would be the solenoid.
Ian Mine: 72 w/ k301, 3 125's, 1 w/ hydro lift, 38,42, & 2 48 decks, 2 42 front blades, QA-36a & QA-42a thrower, tiller, lo-boy 154. Also, LOTS of parts. family's:2 105's, 2 106's, 149, 2 lo-boy 154s, Farmall Cub. Non-IH: 1940 JD Model A, 1954 JD 40 U, 1955 JD 40 Crawler, 2 1956 JD 420 U's, both w/ Henry Loader and Backhoe. JD 110. Wheel Horse (model unknown.) Power King 1614. We love our tractors! ![]() |
Check ALL your grounds and connections. Probably something very simple.
Brian April 1979 1200 Quietline 44A deck 1988 1211 customized into a 1288 with a K301AQS 38C deck and a 1864 54” deck . Snow blades 42" and 54" . Brinly disk, brinly plow a cultivator and a $5 brinly yard rake! ![]() |
Thanks for the help guys, looking like a solenoid. Wired the battery straight to the starter generator and it turned over. The wiring harness and grounds appear to be ok. Gonna start with solenoid and see if that's the problem!
Buy a decent solenoid. I bought one awhile back, lasted two mowing sessions. Was a cheap one.
Before you start throwing parts @ it you might want to run a jumper hot wire to the sol small terminal and see if it turns over.
AGREED. Although you might be lucky and the solenoid might be the culprit, more information and troubleshooting is necessary. Could be wiring connection, clutch safety switch, key switch, etc. As jon asked is the solenoid working? Can you hear it click in start position? Measure twice, cut once
Jon sent this to me. Using a test light, hold the key in the start position and see if your getting power to the small terminal on the solenoid. If the light lights, but still no cranky, cranky.... then the solenoid is bad. If the light doesn't light, it may be a safety switch, or the key, or wiring. Trace the start wire from the key. Hope that helps!
