Old 07-23-2015, 08:45 PM
USMC_SGT USMC_SGT is offline
Default Bare metal prep?
Never done anything "real" with paint prep, what do you all suggest for preping bare metal? Self etch?epoxy? Specifically my SGT braces...
I have some variprime 615s and 616s(activator) that was given to me. Is this the right stuff to use?
How about for the aluminum rear?
I want, and am willing, to do this right.
Old 07-23-2015, 09:35 PM
bocephus1991's Avatar
I would make sure it's clean of oil, dirt , moisture and rust. I wipe or spray down bare metal with acetone. I would stick to epoxy primer. It's very good primer. Works on steel or aluminum. Here's what I use at work.
Brian
Old 07-27-2015, 11:08 PM
Duponts Variprime is a very good product and will work for what your doing. It works on bare metal and aluminum.
Make sure you use a proper respirator when spraying just like all paint. Your health is very important!!
Randy
2 original cub cadets
1 100's
2 149's
1 73
1 2182
Old 07-27-2015, 11:13 PM
Also, you can paint right over variprime, I like to use it like a sealer over what I am painting.
It should have directions on the can on how much time to wait before putting on your color.
I painted a fleet of concrete trucks one time with variprime and Imron. It would take a full 8 hours of painting to do one truck!
Randy
1 100's
2 149's
1 73
1 2182
Old 07-28-2015, 02:57 PM
Thanks for the suggestions, I ended up using Eastwood Chassis Black and associated primer. I have used it many times before with exceptional results, not sure how/why I didn't think of that before. I'll post some pics in my SGT thread later today of how they turned out. I think I'll save the Variprime for this winter when I redo the sheet metal for the 2182.
Jon
