Old 09-20-2015, 09:22 AM
Old Skool Old Skool is offline
Default troy built tiller
OK so I bought a used tiller that needed some work. I have everything done except for removing the tines to replace the leaking seals. This is where I ran into trouble. I removed the bolt that holds the tines on and it won't come off. Soaked in penetrating oil for 4 days smacked it with a hammer, and currently have a puller on it. Also heated with a torch while puller was on and still no luck of coming off. My last idea is to remove engine and handle, and submerg into a plastic barrel for an electrolysis treatment. What do you guys think?
Old 09-20-2015, 09:58 AM
Is it a horse tiller?
Old 09-20-2015, 10:15 AM
RR1862CC's Avatar
RR1862CC RR1862CC is offline
I have redone several of the Horse models and and they are great tillers. I usually just put a BIG puller on the tine holder put pressure on it and smack it with a big hammer. I have larger pullers than most auto shops so I can really put the pressure to it.
If you need another one I have a couple that did not sell this spring.
Allis Chalmers 416
Massey Ferguson MF-8
Brinly 10"plow
Old 09-20-2015, 10:45 AM
It's a pony model, basically the same as a horse. Guess I need to get a larger puller and a BFH!!
Old 09-20-2015, 01:51 PM
RR1862CC's Avatar
Yeah it takes a lot of pressure to get it broke loose from the shaft and key. The puller I use is for trucks or heavy equipment bearings. Then I put a half inch inpact on it and it usually pops right off with a couple of strikes from a big hammer.
I got the seal numbers from MTD and ran them through NAPA and saved some on the price. Do not know about the Pony though.
Allis Chalmers 416
Brinly 10"plow
Old 09-20-2015, 04:05 PM
I use the Posi lock pullers. Is that what you have?
Old 09-20-2015, 04:14 PM
RR1862CC's Avatar
Those or a large two jaw puller
Allis Chalmers 416
Brinly 10"plow
