Old 05-20-2015, 01:40 PM
Hubman's Avatar
Hubman Hubman is offline
Default Wiring . Safety Switch how important .
EDITEDHi all , Last Friday my 123 decided to die. Immediately jumped to the conclusion my head gasket went . Painful troubleshooting process but decided was wiring harness, been procrastinating . It certainly needed to be replaced for a long time .
Well now the new one is in and went to start and nothing happened when turn key . Long story short I by passed safety switch located below steering wheel tower . It now runs and turns off by key . How important is the saftey switch . Can I run the tractor without damaging anything with switch by passed .
Old 05-20-2015, 01:49 PM
You might damage yourself or something else as it may start in gear w/the switch bypassed.
If it were mine, I'd check the switch as that is what's most likely bad. Did it start and run before w/o the switch bypassed??
Have Ya got all the wires on the correct terminals of the ignition switch?
Old 05-20-2015, 02:01 PM
Hubman's Avatar
Thanks for quick reply . I had a frayed wiring harness for a long time . Yes it started last Friday . Died cutting grass would turn over but not start . Thought head gasket leak . wrong . Decided it was my shorted out wiring harness . New one installed would not turn over at all . When by pass safety switch all works fine .
So the purpose of safety switch is for it to only start in neutral ? Would it also need to have the brake on to start if switch was working correctly ?
Old 05-20-2015, 02:24 PM
You will not damage any electrical components with the switch bypassed.
As stated before, it's possible that you could hurt yourself, someone else or cause some property damage, with the switch bypassed.
Truth be told, I probably have as many tractors with the switches bypassed as I do with the switches in working order. Fortunately I have never had any kind of issues, but I'm getting older every day and some day I expect that I'll try to start something while it's in gear and Lord only knows what kind of fiasco may result.
Old 05-20-2015, 02:40 PM
Brake depressed insures trans will be in neutral and the switch will make contact the way the linkage is constructed. Is the actuating spring still in place? broken? missing?
I believe that switch is the only one involved on the 123, so if it IS working, your problem lies elsewhere.
Consult the wire schematic for your tractor (links are here on this site) and do some testing.
Who built your wire harness?
I'd contact them
Old 05-20-2015, 03:23 PM
Hubman's Avatar
Thanks Yosemite , this is just what I was hoping not to damage any electrical components , able to finish cutting grass . Will look into seeing if safety switch is damaged later .
Old 05-20-2015, 04:03 PM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
I would be astounded, amazed and buy lottery tickets if I was able to get my 127 started while it was in gear.
Old 05-20-2015, 04:51 PM
TheSaturnV's Avatar
Hydrostats are funny that way!
Old 05-20-2015, 05:07 PM
OCC does not allow the discussion of how to bypass safety switches. Please refrain from this in future posts. I edited you original post.
Thanks
Old 05-20-2015, 05:17 PM
Hubman's Avatar
Default Oopps
Sorry , thanks for editing out the offense . Will not do in the future .
