Are these wear spots on this steering box a concern? (I will dig out the assembly and see how it works, but figure there are lots of good opinions here)
You should clean up the end of the pin so you can properly adjust it when you reassemble. I chucked mine gently in my cordless drill and brushed it a few times with a flap disc on a grinder. A drill press is probably easier so you don't have to hold/run 2 tools at once, but I don't have one. It worked great and pin came out like new.
Bill |
You can find new ones on fleabay with all new ball bearings for $15 shipped. Search Cam Follower for Ross steering. While you are in there you might as well do the easy steer upgrade using a thrust bearing.
127, 129, 149, 42" blade, 2A Tiller |
![]() Quote:
http://www.onlycubcadets.net/forum/s...ad.php?t=20875 ![]() $8 plus shipping |
