Old 04-28-2015, 06:08 PM
ka9egw ka9egw is offline
Default K301 air cleaner screws
So my brand new Kohler carb, has 5 air cleaner mount holes, 3 of them located at 4/8/12-o'clock tapped 10-32, and two at 3/9-o'clock tapped who-knows what. Bigger than 10-32, smaller than 1/4, smaller than 6mm...definitely a fine thread, and a sloppy-loose fit to a 10-32...and my air cleaner back plate has holes at 3/6/9/12.
Anyone else run into this? Could those holes have been threaded 12-28 [now there's an obscure thread] or 3/16-32 [even more obscure, and close enough to 10-32 they shouldn't be that loose]? I could take them out to 1/4-20, I have bottoming taps, or I could helicoil to 10-32...too many choices.
If they're some other oddball thread, anyone know what it is?
Thanks, Brian
Old 04-28-2015, 07:12 PM
What is the Kohler Spec Number on that K301...???
Old 04-28-2015, 08:31 PM
The carb flange has no markings on it. The box it came in is labeled "B11069". The tractor came to me with a 7-horse non-cub kohler scabbed into it. The motor came with the tractor as a rebuildable core. I only know it's a K301 because I measured the bore and stroke...
Here's a pic of the carb mouth; you can clearly see the holes at 3 and 9 are bigger than the 10-32's at 4/8/12:
Old 04-28-2015, 09:00 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
Roland was referring to the SPEC # on the tag that is behind your fuel filter with yellow paint on it. Can you clean it up and see the number?
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 04-28-2015, 09:45 PM
sawdustdad's Avatar
Drill holes in the air cleaner base at 8 and 4 for the 10-32 screw holes?
Old 04-28-2015, 10:00 PM
bocephus1991's Avatar
If your talking about the plate that mounts to the carb those bolts/screws are notorious for stripping. I drilled and tapped mine to 1/4 20 .
Brian
Old 04-28-2015, 11:03 PM
Be happy to clean the plate off, but keep in mind this engine is likely not original to this tractor, this shroud is likely not original to this engine, and the carb I just bought separately.
The guy I bought the tractor from had, I dunno, maybe a dozen of them, give or take, in various stages of disassembly and/or cannibalization...
Old 04-28-2015, 11:04 PM
OK, so there is enough meat to go 1/4-20. Thanks!
Old 04-28-2015, 11:06 PM
Take it easy go slow and not to deep, you'll be fine. Aluminum drills easy!
Brian
