Hi all,
Should all NF have a brass fuel line with a bowl? Only my 105 does and I guarentee the other ones that have a rubber hose are not factory. So if the gas tank was attached to the engine it should have brass line? Thanks
Pretty sure "factory" is steel, not brass.
Nothing wrong with using rubber. |
Thanks for the quick answer. I'm restoring these so just trying to get what should be on there
If it's a restoration, I completely understand wanting "OEM". Check with Lew, but like I said, pretty sure OEM was steel.
only the original had copper fuel line if I recall correctly. the 70 on up all had steel fuel lines until the wide frames.
Thanks all for the answers.
My 100 and 70 has a steel line and brass fittings.
Project Uncle Dick Cub Cadet 70 http://www.onlycubcadets.net/forum/s...ght=Uncle+Dick |
I started making some sets for the 10-14 hp ones,I need more rubber bushing material for the 7 hp ones
You going to make up enough to share?
He has shared in the past but I think he shared too much. I can say that now
