Hi yall I have a quick question I'm certain someone on here can easily answer... the back part of my generator/starter has a tab broke off. Question is What type of metal is it and can it be welded/brazed back together or am i better off trying to find a new one somewhere? Thanks in advance and hope all of you had a great weekend. Go Duke!
i believe its cast aluminum, your best bet would be to find a new one.
It will either need to be tig welded or replaced.
Craig made a new one for his starter / generator http://www.onlycubcadets.net/forum/s...ad.php?t=36647 |
I would replace it if was me.
My local NAPA store had a replacement starter end frame. Not sure what the part number is.
Project Uncle Dick Cub Cadet 70 http://www.onlycubcadets.net/forum/s...ght=Uncle+Dick |
Thank you Tim and Jeff that was quick and helpful. Ill see if i can have it welded tomorrow. I'm planning on getting paint underway Tuesday.
Theres a NAPA not far from here ill take it over and check thanks Merk
If you get it welded, your going to have to remove the paint....
If i have to ill just repaint that piece separate later on. No one said this restoration job would be easy lol. Thanks J-Mech
Hello, and when you get it fixed, don't tighten those end bolts to tight. The adjustment bolt will hold the belt tight. Mike
