Old 08-24-2015, 06:28 PM
timbo2's Avatar
timbo2 timbo2 is offline
Default Flex disk question
Well my 1650 is all back together, new cork gasket fixed the leaky rear.
Now I'm on to splitting my 1450 which leaks even worse. I noticed it only has single flex disks on both ends of the shaft where the 1650 had a doubles on the hydro end.
looking at this pic It appears 2 disks would fit well. lots of wave in that single disk.
any thoughts?
thx
- Tim
Old 08-24-2015, 07:34 PM
j4c11's Avatar
j4c11 j4c11 is offline
Put two in the rear and one in the front.That way, if it's to break, the one in the front will break.
Old 08-24-2015, 08:18 PM
twoton twoton is offline
Looks like two might fit. Put two on my gear drive;
http://www.onlycubcadets.net/forum/s...&postcount=135
May be time for a fan too?
Terry C's Avatar
Terry C Terry C is offline
I like that logic.
I think the blades on the fan seem short or maybe just an illusion
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 08-24-2015, 09:38 PM
timbo2's Avatar
Thanks guys,
The fan is toast- I was wondering if anyone would say something, it has about half a fin left.
I have a new one to put on during this teardown. Doing the steering box rebuild and cradle mod after I get the rear back in.
- Tim
Old 08-24-2015, 11:35 PM
If two will fit without putting too much pressure on the connecting components. I would probably do it.
Old 09-11-2015, 03:27 PM
timbo2's Avatar
Well the 1450 is getting put back together. Completed cork gasket and steering rebuild so finally got the flex disks and new fan on the shaft.
Here is a pic with 2 discs.
- Tim
Old 09-11-2015, 04:05 PM
On my 1450, I have dual Flex Disc's on both ends.
Old 09-20-2015, 07:28 PM
NealC NealC is offline
Default Info on second flex disc
timbo2,
This info is a little late, seeing how you already have everything back together, but there was a change to the drive-shaft set-up in the quietline series on later units.
Earlier units, 622951 and below(as listed on cubcadet.com), had single disks on each end. The joint had a ball bearing to help with alignment/spacing of the shaft. Later models eliminated the ball bearing. The drive-shaft was lengthened slightly at the rear to allow it to go into the alignment bushing in the rear coupling (the one fixed to the hydro), and a second flex joint was added to the rear.
If you have the shorter driveshaft that used the ball, putting the second flex disc on it might not allow the driveshaft to be fully in the rear alignment bushing. Once the flex discs get some wear, you might develop a vibration at the rear of the shaft.
