In the market for 6x12 ags. Noticed that the carlisle tires and the firestones have diffrent lug angles. Coming from tractor pulling the tire with a "laid" back lug or flatter/less angle will hook the dirt better and the more angle will tend to dig more and chisle into the ground. I was thinking that the laid back lug for this would be better but have little to no experience with moldboard plowing. This will be on a 71 and these will probably only be used in the summer and be removed in the winter. Any help and pointers would be greatly appreciated.
I have loaded Carlisle's on my 108 and it has no problem pulling a plow.
If you have loaded or weighted tires and chains you would probably get along ok with that. I've seen guys run those and get along ok.
Brian April 1979 1200 Quietline 44A deck 1988 1211 customized into a 1288 with a K301AQS 38C deck and a 1864 54” deck . Snow blades 42" and 54" . Brinly disk, brinly plow a cultivator and a $5 brinly yard rake! ![]() |
I have loaded nanco's tires they work good
Most any loaded and weighted ag tire will do fine.. In my opinion the Firestone is still the best overall pulling tire without too much digging..but also the most expensive... The Carlisle Tru powers pull well also but will dig a hole in a hurry if they spin much at all..
Jay 40 years of Using and playing with IH Cub Cadets! Proud owner of the following: Cub Farmall, Super A Farmall, Original, (2)70's, 72, 100, 102, 123, 105, 125, 127, 108, 128, 1450, (3)782's, Yellow 982, 1782, "Sam's" 2182, M Farmall and a #7 trailer |
![]() Quote:
![]() Nothing better than a 23° Firestone, if you can afford them. ![]() |
I have the Firestone 23's on my 147 & 149 their great. Doesn't matter dirt , mud ,snow or ice, also have them loaded with Rim Guard About 82# each. Haven't needed chains or weights.
