Old 01-24-2015, 11:13 PM
crossingcrown's Avatar
crossingcrown crossingcrown is offline
Default Top carb spring
Is it normal for the top screw on a 1250 carb to come loose.. Is this a indication that the spring might be going?
I am broke, but I make it work!
Old 01-25-2015, 12:02 AM
Which screw? The idle stop? Or the main jet?
Old 01-25-2015, 11:10 AM
the one at 12 o'clock not the 2 o'clock.. I cant find my manual. to say the proper name..
Old 01-25-2015, 11:17 AM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
If you are referring to the main mixture adjustment screw with the spring under it, which I believe you are, I would say the spring is weak or threads are bad. Pull the main and idle screws out and compare the springs.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 01-25-2015, 12:31 PM
That or the carb is full of crap and the screw is too far out so that it can get fuel.....
