Old 01-27-2015, 07:26 PM
finz68 finz68 is offline
Default 1962 Original clutch/brake pedal
The clutch pedal no longer springs back to engaged position- If I do it manually, it engages.
Old 01-27-2015, 07:30 PM
Seems like you need a clutch return spring or the clutch pedal is sticking.
Up to 530 and counting...
Old 01-27-2015, 11:14 PM
If you have to pull the pedal up to get the clutch to engage, it sounds like the T.O. bearing has worn the shaft and is getting caught. Time to pull it apart and rebuild/replace the entire assembly.
