Old 05-24-2014, 05:28 PM
yeeter yeeter is offline
Default Internal or external brakes
Anyone have a preference?
(the back story): A short stop on the way home from work Friday and another 1650 (lord help me, I have been trying to REDUCE not increase!). Just a price I couldnt pass up. (took the hood and fenders off before I got a pic, so will only have the 'after' photos)
But Im determined to make some progress on these over the weekend - another thread for that.
This one has external brakes. Seems appealing to me... maybe someday I want to add steering brakes. But it wont happen on this tractor, this one will be passed along to someone that will use it more (still needs a lot of work, and I havent heard it run yet so it may or may not have a decent engine, time will tell).
But I have another one - a 784 that has some rear end leaks. Wondering if I should just swap out the rears ends (I happen to have two extra rear end/hydro units, but neither of those with external brakes).
Should I put this one with the external brakes in the 784?
Also happen to have an 1811 (intended to be my keeper)... I could swap this cast iron one out into the 1811 - a good idea?
Or (most likely), I will just work my way through them until I get them all put back the way they came
Also it has a hitch of some type on the back - anyone know what that might be good for?
Old 05-24-2014, 07:14 PM
I like & prefer External Brakes. That is my story & I am sticking to it.
Old 05-24-2014, 09:12 PM
I like internal brakes. Less hardware and adjustment and allows room for weights on the backside of the rims. But on hydro's brakes are rarely used or needed, with the exception of parking on inclines and during transportation.
Old 05-24-2014, 10:29 PM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
Default brakes
I like the internal brake because its almost maintenance free and I have never seen one that is worn out.... I have put many external pads on over the years... but you really don't need brakes on a hydro so they may be ok as just turning brakes...
Jay
Proud owner of the following:
Old 05-24-2014, 10:35 PM
Nice find on the 1650!
Old 05-25-2014, 06:24 AM
This has both internal and external
Old 05-25-2014, 07:36 AM
Nice Sam!
Old 05-25-2014, 10:11 AM
dbuck dbuck is offline
Smile
:Morning In assuming that all hydro tractors go to neutral when you step on the brake pedal. How is it possible to install turning brakes without effecting the neutral position when stepping on the brake pedal?
Old 05-25-2014, 11:12 AM
You have to make the "turning brake" mechanism just pull on the individual brake rods....cant pull on the cast brake lever, or disconnect the one linkage that operates the neutral return.....thats why i personally like the idea of heel controlled steering brakes....also would be good in a tractor with an open rearend, when getting stuck, to transfer traction....
Old 05-26-2014, 09:29 AM
I like the internal brakes as well.
