Old 12-16-2014, 07:42 PM
BrandonC BrandonC is offline
Default Missing Serial Number Tag
Forgive my ignorance but I need some assistance. I bought a 1250 yesterday and it's my first IH Cub. The previous owner said that he believed it was a 78 model but I read that QL's with external brakes were pre 77. That sent me on a hunt for my tractors serial number to verify what year it is. It looks like the tag was likely torn off years ago judging from the paint damage and rust in that area. Is there anywhere else I might find the serial number stamped into something?
Old 12-16-2014, 07:48 PM
IHCadetCollector's Avatar
IHCadetCollector IHCadetCollector is offline
Unfortunately, no. Unless someone has figured out how to date tractors based on casting numbers if that's even possible. Maybe it's just a part number IDK.
I lost track of what I own a long time ago!
Old 12-16-2014, 07:53 PM
Unfortunately, no. You might be able to use the serial number of the engine as reference.
Like I've mentioned before, knowing the year is really of no use. Everything is done by SN in the tractor world. Year is really irrelevant unless just for bragging rights, or personal knowledge. I would say the PO just didn't know.
I do not know if there was some year cut off for the brakes, but I do know that the parts book shows no serial number break for the brake system. It either has internal or external brakes. I'm going to say that they were just made one way or the other with no regard to when they were produced. May have just been a cost/option thing.
Old 12-16-2014, 08:01 PM
I know it really doesn't matter. I just wanted to know for personal knowledge I guess. I was born in 75 and was kinda hoping it would end up being a 75 as well. Thanks guys.
Old 12-16-2014, 08:25 PM
If it has a cast iron grill it is more than likely it is an early model
If it has an aluminum grill it is later. They also have the wire harness running through the firewall on the starter side rather than under it. The later ones also had the PTO wired on the starter side rather than going down along the carb side frame as the earlier ones were.
These are the differences I have found in 10 or so QLs I own.
Old 12-16-2014, 10:07 PM
what size gas cap?? and what size front spindles??, i have a 75 and it originally had a small gas fill and .75" front spindles...also, as stated above, a cast iron grill frame....trying to remember what else.......??...
Old 12-16-2014, 10:19 PM
kostendorf's Avatar
Rear lift lever? One had a rod to hold it on and one used Frankenstein bolts.
Old 12-16-2014, 10:23 PM
kostendorf's Avatar
Automatic or manual hydro valves.
Old 12-16-2014, 10:24 PM
kostendorf's Avatar
Oil pan, cast iron or aluminum.
Old 12-16-2014, 11:36 PM
The grille support is cast iron, the harness runs down the right side. The engine oil pan is aluminum, the lift lever is on a rod, and the relief valves have a little nub sticking out of the top so I guess they are manual.
