Old 03-28-2010, 12:39 PM
CC Rider's Avatar
CC Rider CC Rider is offline
Default Front PTO's
A while back I took a long weekend in Fl. and on a rainy afternoon went to an indoor flea market. A guy was there selling a bunch of lawnmower stuff ..... engine parts, blades, tires, etc. I bought 2 PTO's (complete) for 10 bucks each that look to be in nice shape. Not wanting to lug them around 3 different airports I mailed them home and just opened the box yesterday. One of them has 2 friction discs in it. Has anyone heard of doing this before? Is it a screwed up way to compensate for weak springs or is there some kind of benefit to it that some old timer knew about?
Tom
CC's - 108, 122, (2)124, 149, 1320
Old 03-28-2010, 01:00 PM
Merk Merk is offline
The 149 and 169 had problems eating up PTO clutch because of the power the motor made. The double disc fix the problem. I think Cub Cadet change the material in the clutch disc. My 149 only uses one disc in the PTO.
Old 03-28-2010, 05:36 PM
wshytle wshytle is offline
That is ironic how you posted a question similar to mine at almost the same time. What Merk says makes sense. The torque thrown out by these bigger engines is a bunch. I am still stumped as to why the ability to adjust is not there using one disc. I understand they act as spacers as well as adding strength and can't spin independently because of the basket. I wonder if IH offered longer springs (the 3 between the pressure plates) for this application and that's what I have now. This pto will not work with one disc. I guess it could be the work of a po changing out the springs too with ones a tad longer.
