I have a 102 I bought in about 1977 and used for a number of years to mow with. I later got a 1641 and 'retired' the 102. It's been sitting in my shed to be gone through as a retirement project (1 yr., 9 mo., 12 da., but who's counting?). Now the question. I bought the 102 from an IH dealer who was a family friend. He had taken it in on trade with an ailing motor and had his shop replace it with a K301. Is the motor the only difference between a 102 and a 122? If so, I thought that when I get around to going through the machine I might put 122 decals on it. It won't be for sale so I won't be trying to defraud anyone, a simple # check would expose that anyway. I was thinking that if the K301 makes it essentially a 122 I might label it as such. Or would this be grounds for scorn and ridicule?
![]() Not the most important ? of the day, just wondering what others thought. |
Heah Darryl. I don't see a problem with it. Your not trying to pass it off as something it's not for profit or anything. It's your tractor, do with it what you want. And like you said a quick check it serial numbers you can tell what it is. I have that 1211 I'm gonna redo as a 1282 just because I always wanted a red cub and can remember looking at the sales ads and wanting dad to trade for a 1282, glade he didn't. I say go for it!
Brian April 1979 1200 Quietline 44A deck 1988 1211 customized into a 1288 with a K301AQS 38C deck and a 1864 54” deck . Snow blades 42" and 54" . Brinly disk, brinly plow a cultivator and a $5 brinly yard rake! ![]() |
I also purchased a 102 with a K301 in it. I also bought a 122 that will donate it's better parts like the hood and fenders. Other than the engine the only difference is the seat. The 102 has the rubber seat and the 122 has the padded fiberglass seat. There were supposed to be some 123s that came with a rubber seat too. I personally like the rubber seat better. So I will have a 122 with a rubber seat. And I am fine with that!
Oh and as far as I know you can't determine the model from the serial number. ![]()
Travis 1993 Cub Cadet 2064 1988 Cub Cadet 2072 1980 IH Cub Cadet 782 w/CH20 1966 IH Cub Cadet 102 w/K301 1961 IH Cub Cadet O 1967 IH Cub Cadet 102 & 122 ![]() ![]() ![]() ![]() JD 2155 w/ 175 loader |
The only difference in a 102 versus a 122 is the motor. Serial number range for the tractors is the same. If you swap it, and someone does check the serial number, they would never know if it rolled off the factory floor as a 102 or a 122.
I changed a 1641 into a 1864. I was very careful to also change the frame serial number tag to match the new confuguration. Everything on the tractor is as it should be.
![]() I only did it for a joke as I fraternize with some Corvette guys that go nuts over "numbers"! ![]() Personally, I couldn't care less! |
![]() Quote:
the 102/122 have nothing in the serial to identify a specific model.
For crying out loud it's only a garden tractor. Do what you want to it.
149,682,1641,1711 with a 12hp in it 1 8" brinly plow 1 10" brinly plow 451 snow blower,H-48 International snow thrower 42" york rake with fold down grader blade. |
Badge it the way you want to, there is nothing in the serial number that will give you away.
As long as you're not trying to deceive anyone, you're ok in my book.
![]() Quote:
