I bought a CC1450 this January that came with a 3 point lift and some implements. I need some help with what I need to attach them to the tractor.
It came with a #2 tiller complete with the gearbox and bracket. The bracket is bolted on the back of the trans axle and the tiller attaches to it no problem. The deal also came with a Brinly BB-360 scraper box. I tried to put it on the tiller bracket and it didn't fit. What bracket do I need to mount the scraper? Is there a bracket that will allow attachment of both the tiller and scraper? TIA, Bob Elliott |
Bob
Can't say for sure on your tractor but I think you need the hitch bracket. This is a pic from the 1A tiller manual.
1977 1650 with cast iron lower grill housing, cast iron oil pan, 54" push-snow blade, rear blade, disc-harrow, 44c and 48" decks, Two cultivators, #1 tiller with both extensions, loaded tires, 75' weights and chains, #2 cart. |
Is the scraper sleeve hitch mounted?
If so, you need the lower mounting brackets plus the sleeve hitch ass'y itself The tiller gear box and mount will have to[ come off. Here's what you need This is a set I made Or, longer sleeve hitch units are available to allow the tiller mount to remain and use it's lower case mounts however you may need a longer lift pin for that application |
![]() Quote:
In any event, we need a picture.
Bob,
When you get a chance please post some pics of what you have. ![]() |
All options that was given above are correct you need a sleeve hitch. The long 1 will let you keep the gear box on the diff. Also lower hitch plate if you dont have 1. I would leave the gear box on but how often do you use a tiller?
The problem with taking the gearbox off and on is you most likely have to put a new rear end gasket on each time.
![]() Quote:
http://www.onlycubcadets.net/forum/s...ad.php?t=20875 ![]() |
