Old 09-02-2014, 09:50 PM
jonjunk's Avatar
jonjunk jonjunk is offline
Default 123 project/repower
Hey guys after getting my own 122 running good and finally using it regularly, and getting my friends dads 129 fixed up a little I am beginning work on my 123.
It has no motor so I am taking a Briggs 9hp vanguard and putting it in, the driveshaft is disconnected from the flex/rag joint thing in the rear and it looks like a bear to get at without removing tin around the back, but I have a drive cup and driveshaft connector thing. Will get them onto the vanguard soon then mark the spot were I will need to notch the frame on one side, the other side barely touches the oil fill which the cap can be modified cuz there's another oil fill.
Then I will figure out wiring for the electric start it was pretty much a fully wired motor but untested.
One problem, I want to put a pulley on the pto side of the motor but it has angled splined that I will have to grind off and make work somehow I plan to use that pulley for hydraulic system for my snowplow in the future when I make that hydraulic angle.
122 PTO, lift, deck, weights, and chains clist pick
123 headlights no motor came with the 122
Stx38 free acquisition but its the wrong color works great though
Free craftsman gt 17hp Briggs Intek hydro
Old 09-03-2014, 12:04 AM
Sounds like quite the project, you know the drill.
We want pictures
Old 09-03-2014, 01:21 PM
jonjunk's Avatar
After work tonight I'll get some pics, oh Ya it has headlights too
Old 09-03-2014, 07:49 PM
jonjunk's Avatar
The motor is just sitting in there backwards the flywheel will obviously face the driveshaft.
Old 09-03-2014, 07:57 PM
Won't the engine be spinning the wrong direction facing that way?
Old 09-03-2014, 08:05 PM
Never mind I just read your post.
